Use good DEF fluid ( not out a jug ), keep valves , and injectiors and engine brake plungers  adjusted, get DPF filter and  cat cleaned every 2 years. Keep EGR differential sensor ports clean. Have dealership check truck for software updates in the engine and after treatment ECM,s. Make sure both nox sensors and the newest part numbers and not counterfeit if they have been replaced. No boost pressure leaks anywhere at all . Newest EGR differential pressure sensor and venture pipe installed . Boost /temp sensor clean and  not soot  caked. I could keep going for ever but in reality, everything has to be perfectly maintained and operating for the system to be trouble free.
https://www.bigmacktrucks.com/topic/73095-derate-over-ride/#findComment-535676
lll keep my MB! Turn the key, go for a ride or to a show then back home and say "DAMN than was fun!! NO DEF this or that or anything else. (No recovery trucks/wreckers were mentioned in this story :thumb:)  And welcome to BMT Mad Ram Trucking. ( We need pixs of your truck please) :WELCOME:    .....Hippy
Edited by 70mackMB
Addition
https://www.bigmacktrucks.com/topic/73095-derate-over-ride/#findComment-535677
