So my Jake’s stuck on today had no issues I wen to pull away after dumping and they stayed on and bellowed white smoke got out of the way flipped the switch twice on and off and it went away and they worked fine.  Where do I start? I pulled the valve cover and manually depressed the solenoids and everything seemed to function correctly
https://www.bigmacktrucks.com/topic/73119-1995-mack-ch-e7-350-jake-issue/
Is the clutch switch damaged or possibly flipped to the front of the clutch pedal arm, also, is the switch at the in section pump dirty?  Maybe spray some elec cleaner on it it to remove the grime..
I would agree on the clutch/pump switches JoJo  ;IF it kept screwing up . a one time stick ;;dash switch internal stick =corrected itself (for now).although a dash switch would NOT cause it to stay on.  electrically I can't speak on relays behalf = I don't know the wiring schematics .
