In the photo there are two sensors. Can someone tell me what they are. Also there is a sensor laying behind them. Any idea?
the towel wrapped around the filter housing is gone now. I was chasing down a oil leak and it was the mack filter that the donaldson filter replaced
Edited by Ricky Beals
https://www.bigmacktrucks.com/topic/73148-need-some-help-identifying-these/
that is the fresh air door. on AC trucks it opens automatically when ac is on.
if the AC is on recirculate, it stays closed.
Set the switch to defrost. It is operated by an air cylinder,   or build air pressure above 90 and slowly slide the vent control knob, and you should hear a loud slamming sound, that will be that door opening and closing.. check to see if the air cylinder and the bell crank are in good shape.. just open the hood and look.. Jojo
47 minutes ago, Ricky Beals said:
Well i only have max and norm on ac and it stays closed. Looks like its not working and i really dont see the need to try and fix it.
would you happen to know if these RD’s have a cabin filter? I can’t locate one if they do.
no cabin filter
4 hours ago, Ricky Beals said:
Ok i need to shut it off because i got ac.
what is this door for? Cant open it
With that door shut A/C should work a little better, with this shut it recirculates interior air for the A/C.    terry:MackLogo:
