  • 0
Question
10 answers to this question
  • 0
They keep the spring in line, and saves wear on the box rubber bolsters and torque arms.  Are the spring tips worn or the old boxes, causing them to rattle a bit more than usually?
I have seen those without the Twinkies, but then when re do them I put the Twinkies in..
https://www.bigmacktrucks.com/topic/73159-spring-spacers/#findComment-536913
  • 0
oh.. gotcha...  that sucks. I wonder if you could use a plastic mud flap to make some shims, and slid them between the twinkies and the box?
https://www.bigmacktrucks.com/topic/73159-spring-spacers/#findComment-536931
  • 0
I have never done that, it just popped in my little brain..  Have you found a vendor for the bolster kit?  I have used ATRO many times. It comes with the bolts too.  however, I put washers on both ends of the bolts so the kit is short 12 washers.
https://www.bigmacktrucks.com/topic/73159-spring-spacers/#findComment-536957
  • 0
ok,  well I doubt someone would try to add some cushion to them.  I figured if you were going to do them you might try it, because its your labor and not Hi Dollar labor.
https://www.bigmacktrucks.com/topic/73159-spring-spacers/#findComment-536959
Answer this question...
