2013 Mack mp8 check engine light
Go to solution Solved by Mackpro,
  • Solution
Crank case pressure sensor. They go bad quite often. There is a newer updated part number. You can watch videos on YouTube on where it’s located. Make sure you search MP8 or Volvo D13. The MP7 and Volvo D11 are in different spot.
