The company I work for has a 1993 ch613 mack with a 400 mack engine. Every 6 months or so a head gasket blows and starts using coolant and overheating. We replace the fire rings when we do the head gaskets but still keeps happening. Does anyone havevany ideas why this keeps happening? Thanks.
https://www.bigmacktrucks.com/topic/73293-blowing-head-gaskets/
Did you check the deck with a straight edge, to see if it's flat.  No more then .005" is allowed..  also, where is the leak? Same spot?? Have you checked the liner protrusion? Needs to be within .002" to neighboring cylinder,. The limits are .023"-.029"...
https://www.bigmacktrucks.com/topic/73293-blowing-head-gaskets/#findComment-538717
