I guess it could be one of two things. Either the gauge is broken/sprung and the primary really is functioning normally or the one way check valve at the inlet of the primary system has failed in such a way to not allow air to flow into the primary system. Does the truck have a supply tank (wet tank) between the air dryer and the Primary / secondary reservoirs? Find the line that goes from the wet tank to the primary supply tank and trace to find the one way check valve. Does the low air alarm stay on constantly? If the compressor is pumping fine and the secondary system is filling up fine I don't know what else it could be other than the one way check valve on the primary side or a catastrophic air leak between the wet tank and primary supply tank you can't hear because the truck is running. Or a broken gauge.
