Developed a oil leak on my cooler.
I am not familiar with a oil cooler and therefore any help is greatly appreciated.
Does oil or coolant go thru the small tubes on the core?
Also in the pic is that (about 1 in or 1.5 in) steel line above the cooler oil or coolant.  I think that is where my leak is.  I believe there is a couple of o rings and a gasket there.
Again any help is greatly appreciated.
Thanks
Edited by macattack
https://www.bigmacktrucks.com/topic/73302-school-me-on-my-oil-cooler/
I believe oil goes through the small tubes and the coolant surrounds the tubes. The oil first goes through the oil cooler then it goes to the oil filter assemblies.
Heres a pic from the manual that shows each of the tubes. I think the tube you are referring to carries the cooled oil back to the oil filter assembly.
Thanks for the info.
This pic was taken when there were no leaks.
I will  try to get a recent pic.
Almost sure its oil leaking from the steel tube #10 on top of cooler.  I think #11 the o ring  in the diagram is my issue.
Can that o ring and gasket be replaced without removing the cooler?
Thanks  again.
