My dash cluster randomly blacks out. Nothing works at all. It will randomly come on and be fine a few hours or days then back off again.
dealer said bad cluster, i bought another one to the tune of $1500 and it’s doing the same garbage.
anyone else seen this problem. I saw on here that older trucks had this problem.
i have cleaned the data link plugs on the back- 3 of them
Edited by Scottco
https://www.bigmacktrucks.com/topic/73391-2012-cxu-613-instruments-cluster/
Check all the gray wires above the throttle pedal. Remove the triangular fuse cover to get a good look at them.. and for fun... clean the gray wires outside on the firewall..  Those gray wires are the grounds...
