Problem:  my crd151 is howling and has a ton of metal in the top housing. It’s also causing a BAD vibration.
$6,000 for a reman. I can not seem to find a good used take out in a 3.79 ratio.
im being told CRD92/93 will fit my housing, but they do not come in the same ratio as the 150s so I would have to change both diffs.
92/93 seem to be much cheaper and more available.
Would y’all recommend ditching the 151/150 in favor of the 92/93?
Thoughts and opinions?
Thanks.
https://www.bigmacktrucks.com/topic/73497-crd151-issues-what%E2%80%99s-my-options/
  • 1 month later...
Thanks.
CRD92/93 is old version that has been in production for 40+ years and replaced with CRD150/151 in 2009. The newer axle has slightly better design and rating and capable of pulling upto 150,000 lbs for linehaul applications. You can try to find closest ratio CRD92/93 but will need to ratio match with smaller or bigger tires so as to not burn up inter-axle powerdivider.
Thanks.
My opinion of the 151 is the only good thing about it is the diff lock! KT and I disagree on its reliability ! It has some design flaws from my view point !  92 /93 has the test of time going for it! How ever I think you closest ratio will be around 3.87
