maybe the 31 number stuck in my head from working at baskin robbins  ==31 flavors :LOL  for 34 years. 56gts ;;darn that's alot. another one of those things didn't realize back then  info I should have memory banked.
  • Haha 1
https://www.bigmacktrucks.com/topic/73509-oil-capacity/#findComment-541733
I may be "out in left field " with this ;hopefully someone will correct me.  1-the super large oil pans had a situation with hairline cracks developing in the casting . vaguely remember pulling down the tubs fining cracks near the middle reenforcing braces, 2- when the three oil filter set up FIRST  showed up , was not the rear filter an internal spin/scrapper filter unlike the other two ?, I know the scania had the spinner /scrapper filter. as stated before these forums get the dormant brain cells moving.
https://www.bigmacktrucks.com/topic/73509-oil-capacity/#findComment-541777
1, stamped not cast; I couldn't say, my 79 has had thr sane pan forever. I have had a smaller pan crack pretty bad in a couple corners.
2; my 79 ESI+ has 3 filters, no spinner.  My late 70's early 80's ESI engines have 2 filters. My 1995 and 2003 ESI engines have the spinners
https://www.bigmacktrucks.com/topic/73509-oil-capacity/#findComment-541844
