22 hours ago, tjc transport said:
same here Larry.
by the time i get the old body ready to go out and do anything,  i have to sit down. than once down find it very hard to get back up.
wish I found it hard  after sitting  down. 😱🤣😂 sorry couldn't' help myself (again) LOL
  • Haha 2
How did the extra gauges turn out would like to see some pics I just cut a hole in my dash and got rid of the lighter and added a pryo gauge and yes one small project is never small lol
If your going to be a bear be a grizzly
Haven't done it yet. Might be awhile as I don't have the correct hole saw yet and have other things on the go as well. I did make the plug for the lighter hole, just have to weld it in.
correct hole saw will be a major importance. a size or two smaller and some dremel filing would be my  choice. hole saw on thin sheet metal will bounce  end up way to big possibly. can always file it bigger . can't make it  smaller.
Well, the gauges are 2 1/16" so I bought a 2-1/16" hole saw last time I went to town. Tried it on a piece of scrap and a gauge "fits" but is quite snug, have to use a fair bit of force to get it on there all the way (then had a bear of a time getting it back off) and the saw itself was quite sloppy in the original gauge holes. So, next week when I go to town (to pick up the drive shaft) I will get a 2-1/8" hole saw and that should work perfect. I would much prefer an annular bit but one of those in  2-1/8" would be $$$$$$$ just to make a couple holes so........that's a hard "NOPE". The brand new Milwaukie 2-1/16 saw made a perfect hole when used in the mill and everything clamped down well and run slow so I now feel confident that the 2-1/8" hole saw will be the ticket, just need to get to town to get one.
P.S. I SHOULD be able to finish the welding on the cab today, just have to weld in the driver side front 1/4 and change out the rockers so then I can wheel the welder back to the bench and weld up the unwanted holes in the cluster panel. I HAVE to get the cab done as my son called and he needs the lift to do the brakes on his wife's buggy and my oldest daughter needs her winter tires put on and I am too old (and lazy) to do that sort of thing on the floor any more.
Edited by Licensed to kill
so the "test hole"was on scrap piece which was fasten to bench? is the dash hole being drilled still in the truck  which may flex to much? no dremel with emory  or grinding bit ? to widen that small dia.
I clamped a piece of wood in the vice on my drill/mill table then clamped the small scrap sheet to the wood with vice grips. Will do the same with the gauge panel. I will take a couple pics when I do the panel and post them.
