12 hours ago, Supermutt said:
Checking to see if anyone here has a manual on the Ambac E9 V8 injection pump ?
Type APE  8VBB110Q6418B1 (313CC4362P1)
The E9 engine service/rebuild book does not get into any detail on the pump.
Thank you.
Bro I think you need to go to a bosch pump shop for this ! Did you get the engine to run or still no fuel? ! If you still fighing it remove the transfer pump and get a mirror look inside the hole where it mounts and check the little gear that runs the TF pump it may have fallen off its shaft!
I have fuel to the pump. The lift pump is working, thus the auxiliary drive gear is working as well. I already pulled the lift pump to check that and videoed the auxiliary drive working.
