Should we/are we supposed to run a high ZDDP 15w-40 oil in our older engines?  I have 5 675's and have always run whatever 15w-40 I can get locally, usually Walmart brand; and change it a little more often then some might.   Never had an issue.   But as things wear and get older, and oil specs change....do we need a certain ZDDP content or additive to help out in the wear department?
https://www.bigmacktrucks.com/topic/73724-high-zddp-oil/
