I assume you installed an electric shift PTO? If so where did you wire it to? did you check for continuity on those wires using the dash switch before wiring up the PTO? If all that checks out sounds like it could be a software issue....
https://www.bigmacktrucks.com/topic/73743-adding-pto-to-mdrive/#findComment-544930
20 hours ago, 2015Mack said:
I have a 2015 Mack with an Mdrive transmission.  When adding a PTO and using the PTO switch in the dash, are there things that need to be enabled in the program?  We installed the mechanical part but the switch won't engage the pto.
Yup ! Think its a dealer issue here there are lots of parameters to be set even just enabling it (may not) get the result you expect!
https://www.bigmacktrucks.com/topic/73743-adding-pto-to-mdrive/#findComment-544995
