12 hours ago, JoeH said:
Not sure what the E6901 is. Is this an E6 engine? Or an endt675/6 engine?
The ENDT engines use  plastic fuel return leak off lines that jump from injector to injector and then run back down to the injection pump/fuel return I believe.  These lines get brittle and crack eventually, and 99 times out of 100 I'd bet this is the cause for draining off fuel when sitting. Easy enough to buy a coil of this stuff from your Mack dealer and replace any that are damp.
My friend said the E6901 was the engine.  It is on a plaque on the hood.
