If you think the bumper, bumper to frame extensions and the frame are all straight, I would look to the front radiator mount as the next point to check. There are two rubber mounts in there that support the entire front clip. They are on the bottom of the radiator support frame to which everything mounts and bears down on. If one has failed it can throw the whole front end off. You can use the same rubber mounts for the cab and transmission there. The originals were slightly different as the back side was cupped and made for a softer mount for the radiator. There's less weight there than on the cab or transmission. You can also shim those mounts with large fender washers to adjust if some thing is bent. Pctures would help to see where your alignment is off, as we're all guessing where things are off.
https://www.bigmacktrucks.com/topic/73755-b61-bumper-not-level/#findComment-545164
