I know this question has been probably been asked in the past, but trying the search function and scrolling through hundreds of pages is time consuming so... I'm restoring a 79 R 685 ST and I need to know where the oil temp and oil pressure sensors are to trouble shoot those systems, they're both  inop.  Can someone tell me where those sensors are on that motor?  I wish I could find a manual with all the pieces parts labeled, but till then I'll ask the experienced folks.  I'm sure that info will probably help me on my 66 END 711 project as well.  Thanks in advance.
Paul
Oil pressure should be in top of filter housing.  Oil  temp?  Maybe in the pan would be my guess.
Pressure should be mechanical with a copper line.  Not sure about temp?  Water temp is mechanical, so maybe oil is also?
