- 0
Start for a second stalls
Question
Vicstruckservice
I have a 1998 Mac RD with a e-tech e7 electric bosh fuel injection pump
(only on back half fuel pump). The truck starts runs for two seconds stalls, but starts right back up again no RPM gauge and the emergency shut off light stays lit changed the oil pressure sensor,changed coolant temperature sensor, and rpm sensor on flywheel also checked the wire harness connection on the fuel pump. I also checked all the fuses and relays and are good. we had a extra Bosch, few computer, swapped it out still the same thing, but there is another engine control module that we did not swap. Not sure if that could be the problem. Any help would be appreciative.
https://www.bigmacktrucks.com/topic/73825-start-for-a-second-stalls/Share on other sites
9 answers to this question
