Question
6 answers to this question
  • 0
1 hour ago, Davey Crocket. said:
Question. I have a 2001 mack vision with the e7 460. I'm wanting to put a 1997 e7 454 engine in my vision. Can I? And what will change? Radiator? Hoses locations? Anyone know?
Sorry, I can’t help. I would not guess there would be much changes at all. Good luck I like your handle….bob
https://www.bigmacktrucks.com/topic/73962-2001-mack-vision/#findComment-548085
  • 0
You will probably have to change water pump housing because it sits lower if you change that you may also have to change oil cooler because you probably have plate type on 460 and round on 454 but I think everything will transfer off one another
https://www.bigmacktrucks.com/topic/73962-2001-mack-vision/#findComment-548140
Answer this question...
