  • 0
Radio Wiring for 07 Mack Granite CT713
Question
2 answers to this question
  • 0
G'day David, can figure it out without diagram. There will be 3 main wires, constant battery+, switched ACC or IGN + and a ground, just need a test light/ circuit tester to find them, the rest should be speaker +/- which you can check using a 9v to find the pairs, speaker will crackle when you got the right wires. If you've got steering wheel controls, should be on a separate plug to the power and speakers. See how you go.
Adam
Answer this question...
