Hi,can anyone identify these? I think the big boy on the right is a Luberfiner 750,no idea about the smaller one on the left. And the small one in the middle is a gas filter that you rotate the top to scrape the crud off the wall of the can?Also,someone added what looks like black silicone seal to the cap of the big filter even tho the flat rubber gasket looks to be good.Is this common practice for added leak stopping?Btw,I took the clamp off the lid,it isn`t missing.Thanks in advance.
Edited by skydawg
added pic
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/
I don’t know what to tell you yes the big one looks like a lubrifiner , which is still available through Amazon all I could tell you is take the little one apart and see what the element looks like. Amazon will probably have it too they have everything. Good luck.bob
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-549495
The one on the left is probably the engine oil filter; if the lines go to the left side of the engine block then that's what it is. It's a Luberfiner 500c, filter is a Wix 51554 and the lid seal is a 15414. If you change it, crack open the plug on the lid a couple of turns after you first start the engine and close it when oil starts to seep out to bleed out the air. I can't help you on the other two.
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-549533
Is that big one a power steering reservoir???
Brocky
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-549542
big -luber as stated/ small fuel with scrapper inside have seen and worked on. the middle should be the power steering. did you trace the lines ?? one to PS pump other to box ??
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-549544
smaller on left is an oil ?? did you attempt tracing lines from smaller one  (luber 500)?  going by statement of the 750 gasket is square ; which I'm sure is correct. got me thinking  == there is one large  filter housing having a tapered top which the square o-ring has one tapered side that  faces up when installed to match cover angle.
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-549760
Terry,you`re correct,the filter on the right has two cartridges,stacked.The top filter came out smoothly,the bottom one gets even with the top of the center tube in the housing and comes to a hard stop.I can`t see what could be holding it there,when the top one came right out.These are WIX 51235 elements.Any help is appreciated,thanks.
Edited by skydawg
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-550278
  • 4 weeks later...
The filter on the left says Luber-finer 272-C.Not only is there no filter inside,there`s no center tube,it`s just an empty can.According to the Mack owners manual a pic of the same(or similar)filter has a tube the length of the canister with a T handle on top,same as the large filter on the right.Can anyone tell me if this a complete filter that never had a center tube,or has it been removed?Can`t see why anyone would do that.What would be the correct part# for the element for a 272-C? Thank You.So I guess 272-C is the part # for the clamp for the lid,it`s a 500 Luberfiner,and could have a center tube or not.
Edited by skydawg
https://www.bigmacktrucks.com/topic/74022-oil-filters-id/#findComment-551688
