Fan clutch turning on too early
Go to solution Solved by Mack Gazza,
l have a 2004 Mack Qantum with a 470ccrs motor, have fitted a new fan clutch as the old one would not keep air, worked fine for a while but now it still turns off at the correct temperature but turns on way too early thus running with fan turning on and off too often.
l would like to  find which sensor or thermo switch sends the signal to the ECU for turning on the fan clutch.
Thanks to all of you readers,
Mack Gazza
https://www.bigmacktrucks.com/topic/74066-fan-clutch-turning-on-too-early/
the coolant sensors are at the rear of the rearward water manifold. one is in the side and the other points toward the firewall.  The A/C pressure switch also controls the fan.  there may also be a setting in the EECU for ''Smart fan''.  I cant remember if the air fan has that feature turned on.  I also dont know how Aus. trucks are built, compared to U.S trucks..  jojo
  • 1 month later...
  • Solution
Thanks Joey Mack for the sensor location, replaced the reward sensor which at least told me the old one was working then replaced A/C low pressure switch as you suggested ( the small one closer to the compressor) and whammo it is operating correctly which l am very happy about. 😊
Thanks for this awesome forum.
Mack Gazza.
