  • 6 months later...
CM was available in single axle and tandem.(34,000lb camelback rear suspension)
The term "Frog Dog"  was first used for CS/MS midliner chassis that were only available up to 33,000lb gvwr.
The CM was known as "the Baby 8" which was a Mack frame and axles. Renault or Cummins engine, Spicer or Fuller trans. Straight truck or tractor.
It was the in-between of Midliners and a R models at the time of introduction.
On 4/22/2024 at 1:52 PM, Erickson6111 said:
Data on this CM is fairly hard to find. What is GVWR? Is it 33,001? Or simply however many axles a guy can hook up behind it?
Would be nice to hook up to B-train high boys and go haul hay bales
