  • 9 months later...
A CRD93A (not 931a) has a bigger 2.374" 46 spline yoke spline which uses a larger diameter 46 spline yoke and 3 inch id seal also used on the front differential power divider. The crd93 pinion is 39 spline by 2 inch. If I remember correctly the pinion retainer might also be different to use with bigger bearings but everything else is similar.
https://www.bigmacktrucks.com/topic/74158-crd931a/#findComment-571001
On 5/13/2024 at 7:09 PM, Straydog954 said:
Can anybody explain what the difference is between a CRD931A and a CRD93 rear rear diff. Is one better than the other?
93"1" is designation for IWPD - Inter-wheel power divider i.e CAM limited slip differential. 93 is standard differential. Since CRD92/93 did not have inter-wheel diff lock, the IWPD is better choice for slippery conditions (though it is useless if one of the wheels is spinning on ice).
https://www.bigmacktrucks.com/topic/74158-crd931a/#findComment-571762
