Talking about this on another site, with some who have been crew on a ship, the conclusion was the  engine computer didn't/ wouldn't throttle back and they were faced with shutting it down either electrically or by cutting the fuel, thus putting it the condition the Dali was, or call for assistance and run it out into deeper water and solve the problem out there. We know how the Dali ended up so they chose the other option.  Just as a modern truck engine is not directly controlled by the driver via mechanical linkage to the injectors, the same is true in marine engines.
 To be "hacked" there has to be a connection between the engine ECM and the outside world, but it can just as easily be a internal "computer failure" where the computer just stops reacting to inputs and "freezes" where it is. The conclusion was it very unlikely that it was being controlled by a hacker and far more likely to be an internal failure.
 Ships need the prop turning to have any steerage esp at lower speeds, so by leaving the near shore at a higher speed with C/G escort, they were able to control the ship, if it were hacked, one would think they would want to control the steering as well. That was not the case. If nefarious actors gained control of the ship, it wouldn't just be one system.
 Only damage (minor) was by the wake, no one hurt, so sounds like it was handled well.
  • Thanks 1
