23 minutes ago, Geoff Weeks said:
Just to add a bit of clarity, it take  TWO revolutions of the crank to adjust all the valves, when it point to 1-6 that means you adjust EITHER 1 or 6 not both (depending on which is on TDC compression) then you go to the next mark in line do the same there, when you come back to 1-6 you adjust the cylinder that was TDC exhaust the first time around, and continue on until all have been adjusted.
 Unless it is different then I remember.
So Trent !I got to ask is your damper divided in to three!? Is there the lines on the damper? Firing order153 624. 1-6. 2-5 3-4 once one 1 slack valves set it move to 2-5  set 5 move to 3-4 set three and so on ! Work through the firing order till you’re set! Also the best way to make the dam gaskets stay on is with gasketsinch both cover and gaskets let dri the coat them again and let dri! TWO coats let dri then assemble to the covers! Drop the covers on dri no oil on any surface! Make sure the dynatard washers are flat and contacting the nubs!
just sayin!
Ok that helps explain it better. I only did 1 full rotation as i was adjusting.
I put 1 on tdc in the compression stroke. Adjusted 1-6,rotated 120* then did 5-3, rotated 120* to do 3-4.
Guess I have to redo it again.
Thanks for the help
Mack engines cant be adjusted like a Cat or John Deere, for example,,  Yes, you have to rotate the engine twice and follow the firing order as was stated earlier..  You got this...  Jojo
just sayin!
Yes the damper is as seen in the photo.
Yep. Glad I asked I knew I missed something. I could hear the ticking
Bingo !!
Now if you do this to an ASET with powerleash...  STOP !!  and come back here for the procedure..  :)
your doing fine...  Jojo
  • Thanks 1
did you post a video of it running?  I really glad you took the advice/instrution..  this Web Site is a great resource..
this was last week after I put the heads back on
https://youtu.be/ZXFH3xLgHtM?si=zPMPUuQFagmrnnvT
Yep I saw that one,  well if you want to post a longer vid of it now that you got the valves right, it would be pretty cool..  I'm proud for you..  :)
I'll get a new vid next week 😎
  • Thanks 1
Ok. Got them re adjusted. I checked each set of rockers before adjusting them. I found
Holes 1, 5 and 3 were spot on as expected.
Holes 6,2 and 4 were loose.
After re setting them all to .016 and .024 I fired it off and no ticking sounds like the other day.  I have The incorrect exhaust clamp on the downpipe, so you might hear some exhaust leak in the video.But the ticking is definitely gone from the other day.
Test drove. Builds 24psi boost, Pyro was 950 with foot on brake holding rpm at 1600 in direct for about 20 seconds.
Engine is definitely quieter and smoother all around.  Even at idle it's smoother.
Thanks again for everybody's help.
https://youtu.be/1OGatrOBdl8?si=9Nyouam3FCGJUN8V
4 hours ago, mechohaulic said:
such an excellent sound.  everyone has their own thing; be it sound of trains/ planes/ boats etc.  that engine beats them all. memory maker .
Nope for me a v8 a locamotive or a radial plane engine does the trick!
14 hours ago, JoeH said:
Valve cover gaskets go on bone dry, only torque to spec, no more.  Over torquing squishes the valve cover out of shape, and any sort of glue/adhesive makes the gasket slippery, it'll bulge out of position and leak oil.
have used a small center punch on valve covers bottom side . small indent enough to hold rubber gasket. did mostly when engine had a jacob engine brake spacer and 4 rubber gaskets were used. situation wasn't as bad when the gaskets were cork NOT rubber. yes; did a few engines when valve covers/pan gasket were cork not paper or rubber.
