My 2003 MR688S AI350/Allison hd4560 suddenly just dropped it's low idle speed from 650 down to 500 or less.  No codes, just had a ton of engine work done at the dealer, see my other "rollover" thread under Modern Trucks. Been running great til now.  Firing up computer to check stats, and doing a visual inspection. Any recommendations?
https://www.bigmacktrucks.com/topic/74265-2003-ai-350-sudden-500-rpm-idle/
Yes you have to have the shop set the idle as you have no clutch to make it set on your own! Seen this happen before! Just have them re set the idle! Has to be done with the pro link or laptop! Also make sure to tell them to turn off set idle with switches! If you have the lap top with Mack program do it yourself! key thing thing is turn off set idle with switches!
Can I reset it with switches myself??
Throwing this out into the abyss...
Idle speed is adjustable by driver, assuming the feature isn't disabled.  Punching the right cruise control sequence enters the "reprogram mode", and as you say you need a clutch pedal to set it once you've floated it where you want it. Or you need the Handy Dandy Mack software, which I sort of have but can't utilize because it doesn't recognize the DieselLaptops interface device I own.
8 minutes ago, JoeH said:
The wealth of knowledge here seems to never end. Thank you @fjh! You pointed me in the right direction to sniff this document out!
All good bro! You bet lots of knowledge here we all learn stuff here I never stop picking up stuff!
Never ending. Dealer computer can't program idle speed because VECU isn't picking up that the parking brake is set, even though the dash indicator light comes on saying the parking brake is set. 🤣 Brought the truck home to dig into this myself....
Lol, I thought about that, but the shop foreman didn't think that would work as it's programmed for an automatic. I'm not opposed to trying it but I don't want to fry anything. The task at hand is to find/repair the "VCU Park Brake Switch" circuit. It's wire VJ1-10-0.8.  I found the wire near the VECU, but I need to find where the VCU park switch is.
So the dash instrument cluster has a parking brake lamp that functions, it works off the park brake sensor on the park brake knob. However, according to my wiring diagrams for the truck there should be a VECU park sensor. Any suggestions on where it'd be on an MR688?
Sorry bro I’m going to be of no help on this not familiar with that wiring on these at all! My former suggestion is all I have to offer! If the wires are there! They will have a jumper set the idle and disconnect! We’re the switches turn off when they looked at the settings?will the engine ramp up with the switches?
Even if this were a manual trans with a clutch I couldn't switch set the idle without VJ1-10-0.8 receiving parking brake signal. It can enter the reprogram mode without the park brake signal, but can't program a new idle without it.  Worst case scenario I just have to plumb in a new park brake switch receiving power from 10amp circuit breaker #17 to one side of a park brake switch, and wire VJ1-10-0.8 on the other side of the switch.
8 hours ago, fjh said:
👍 sorry it wasn’t more cut and dried for ya bud!
Wound up being real easy:
Double check on my Mack Flash Drive P/N 23-021 (has every wiring harness of every Mack chassis from 2000 to about 2020/2021) to compare the switch circuit/wire codes from the 2000 MR688 donor truck to my 2003 I'm working on. Circuit identical.
Found wire VJ1-10-0.8 on the 2000 harness which is on my shelf. Appears to go to parking knob area.
Got 2000 MR688 dash panel out of storage box, park knob has 2 sensors on it!
Went to my 2003, only has one sensor, but has a plug in other port!
Found wires nearby, VJ1-10-0.8 is intact, taped to its pair 17-A-0.8 which has been cut short and the end electrical taped.
"Borrowed" a sensor from the 2000 dash park knob which I hate doing, but I used the label maker to leave a note for future use; repaired wire end 17-A-0.8 plugged it all together and ran the test light. System functional, I'll be heading to the dealer hopefully today to get the software side cleaned up! Will post results later!
  • Thanks 1
