there is a pressure switch above the pedals that controls the low air buzzer and light. i dont know which one, but if you dump the air, with the key on you can unplug a wire on a switch and see if the light goes out, that will be the switch.  a replcement air switch is basic . just by one with 1/8'' npt threads 2 blades, normally closed, 80 ish PSI rating.. no need to go to Mack.  Good to see you again, its been a while..  Jojo
Yeah Im still around JoJo. Seems like my life is speeding up and it should be slowing down. Im keeping the old girl up with maintenance and there is always something to do. So I will look for this switch. You think it will be directly above the pedals?
