B42 Low air pressure buzzer
Go to solution Solved by HarryS,
When I got this truck, the low air pressure buzzer worked normally, shutting off at about 60 psi.  Then it started going off all the time.  Then stopped entirely.  Now it is back to going off all the time again.  This truck has great air, no leaks.  Where is the buzzer located?  What is involved in changing it?  Thanks, Doug
https://www.bigmacktrucks.com/topic/74316-b42-low-air-pressure-buzzer/
There can be a few reasons, wire shorting to chassie, but the most likely reason is the low air pressure switch. Where that switch is located will take someone with more knowledge of the "B" line than I. Often they are around the brake valve, but can be other places as well.
