Had to haul a few loads in my 90 R Model and quickly realized it's gutless.
Has a 400hp E7, 12 speed, top loader rears.
All it can do, foot to floor, to hit 55mph on flat road.  Any grade it slows quick.  Had maybe 15k in the bed, if that, was mix of light topsoil, sawdust and wood bits.
Ideas were I should start?
It seems to have an exhaust manifold leak at the last cylinder, maybe last 2, but not severe.  Can just to say hear it and signs of soot.
EGT seems fine I guess, but not sure if the gauge is correct.  Highest I saw was maybe 700*
Thinking to get a cheap boost gauge to check that, what is normal boost?
Otherwise maybe due an overhead, and something is up with the pump?
It has about 8000hrs, so shouldn't be tired.  I've run several dump truck with 2-3x the hours that pulled well.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/
check to see if there is 'play' in the throttle linkage..  the lever on the injection pump may be loose as well,,  my BET is slop in the linkage from the pedal to the inj. pump.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555600
There's play but I have it that pump is WOT before pedal bottoms out.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555605
11 hours ago, JoeH said:
There's your problem. My e7-350 hits 30, and in the right circumstances I've hit 34 psi.
Wheres your pyrometer peaking? 700 I thought you said? Sounds like you're under fueling.  Get your filters changed, check/replace your fuel supply lines. Fuel suction lines can come apart internally, closing off the line internally under suction pressure.
You should also check your fuel supply pump.  If your pyro is running hot, 1000°+, then I'd suspect air problems, i.e. boost leak.
 Lack of Fuel in my opinion as well ! l Check all the simple stuff first !  Fuel tank vent lines and hoses to the pump ! Also if the smoke limiter has a hole in the diaphragm it will be low on juice!  if you can remove the line to the limiter and blow or suck on it if it wont hold a vacuum or you can blow thru it  has a hole in it!
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555675
The info I'm finding is saying 23-25psi max is normal.  No idea what the engine is doing, don't have a gauge yet.
Fuel Filters are new.
No idea if the pyro is correct, I've never run anything with the sensor after the turbo.  Dumb place for it.
Edited by Icehole
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555724
Talking about the fuel aneroid, aka afc?
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555725
If power loss has been gradual over the years. I’d look at getting the pump timing adjusted. Timing gear train wear over time will cause the pump timing to slowly retard. I’ve seen them as much as 2 degrees below spec. I alway set them 1 to 1.5 degrees over the spec on the valve cover. Being in a RD I’d only go 1 degree over spec. CH’s and Superliners with the bigger radiators can go 1.5 degrees over. Also check you muffler. Some of the older RD’s had those small canisters mufflers that broke apart inside. And like the guys said above. Check linkage for  full throttle and especially the kill leverage way forward. Chased a low power issue for over a day one time and it was the kill lever not adjusted. Also if truck has an air ride cab , be sure to check the linkage with the cab aired up. Check air filter for being put in upside down( don’t think it will even run that way though)
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555739
I'm not sure on gradual, I bought it 2 years ago and this is the first load it hauled.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-555804
  • 3 months later...
Moved it last night to park for the winter and noticed it cranks "choppy" like it's got less compression in a cylinder or two.
Like a waa waa waa wa waa wa.
That typical?  I've run some equipment that it was just how the starter was.
Aside from the low power it starts fine, idles fine, I think.  It vibrates the cab, but isn't much worse than the much newer trucks I've run.
Little bit of smoke when cold, but nothing unusual.  Like last night it was maybe 10*
Does take 15-20+ seconds of cranking for the first start if it sits for a while.  Was probably last started 3 months ago.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-561884
  • 3 weeks later...
On 11/13/2024 at 10:42 AM, Icehole said:
Usually with a dead cylinder it'll be pretty hard to start, especially when cold,, and idle/run bad, at least in my experience
Starts fine and runs fine aside from it being gutless.
Have to crank a while when it's been sitting for weeks but otherwise it's no different than any other big diesel I've owned or run.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-563039
Hook a fuel pressure gauge to it right at the injection pump. Rig the gauge up someplace you can see it while you drive. and see what your fuel pressure is under load. All you need is a gauge, a long piece of hose (even synflex) a tee and some fittings.
The big thing is you need to drive the truck and pull a hill or something or the readings don't mean shit.
https://www.bigmacktrucks.com/topic/74363-low-power-e7/#findComment-563041
