My 1995 F150 had a check engine light on. I put my OBD1 reader on it, it showed some minor codes (brake lights, reverse light, etc.), the main code was 172.O2 sensor. I disconnected the battery and replaced the O2 sensor. The check engine light came back on with in 2 miles, maybe 10 minutes running. It is showing the same codes, 172 being one of them. Is there something else to do to reset codes on an OBD 1 system other than disconnecting the battery? Or does anyone have an idea why the 172, O2 code would keep coming up?
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/
sometimes you need to drive a "readyness" route to reset the computer to no codes.
certain number of start/stops, varying speeds.
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/#findComment-556425
My 91 Ford F250 has a similar problem, the check engine light is on all the time and it runs rough. It used a herculean amount of gas but I don't really care as it's just a fuel truck now. I've never really liked the 351 so I might swap it out someday.
Haven't had as many issues with Chevys fuel injection system of that same era.
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/#findComment-556426
most of the time the check engine light comes on because the gas cap fails, or the person who puts it on leaves it loose or never puts it back on.
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/#findComment-556471
My daily is a 95 F150, 302/auto.  Absolutely love it.  It has 177k miles on it now.
Since you replaced the 02 sensor I would start looking at fuel issues.  It was likely reading out of spec, but it may just be running rich due to too much fuel?  Too little fuel?
How many miles on injectors?  I just replaced mine due to dripping.  It was hard to restart after like 30 minutes of sitting.  Friend has an injector cleaner, so I installed a fresh set and it runs/starts flawless and mileage actually increased about 1 mpg.
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/#findComment-556538
All the code is telling you is the output to the "computer" is outside what is expected. It is up to you to determine the cause.
 Looking at the actual O2 sensor output might be of help, it would show if it is sensing rich or lean condition.
The older the system, the less info it can provide.
Depending on how "slightly different" the cam you put in is, it could even effect what the O2 sees and the computer is expecting to see.
 1st place I'd look is for vacuum leaks and rich running do to fueling issues, 1st causes lean running 2nd rich.
https://www.bigmacktrucks.com/topic/74415-older-ford-issues/#findComment-556540
