I am looking at an 07 Mack with 75000 mi and 8800 hrs. Because the odometer reads 75k miles would that be correct or is there any way that it could be more than what it’s showing? Also what problem does an illuminated orange lightening bolt on the dash stand for? It’s an MP7 engine.
https://www.bigmacktrucks.com/topic/74445-hours-miles-q/
Seems like a crazy amount of idling time. I was always told the average mph for a vocational truck such as a steel body dump or roll off operating a mix of suburban and city conditions would be somewhere in the 20-30mph range. Don't know what the use of this truck was but those numbers indicate a lifetime number of 8.5 mph.
https://www.bigmacktrucks.com/topic/74445-hours-miles-q/#findComment-556751
Seems like a lot of hours compared to the miles. There also might be a lot of life left in that engine too.  The ECM should have the information in it if it's what's actually on it.  Good candidate  for an oil sample (oil analysis)    They were pretty good engines
https://www.bigmacktrucks.com/topic/74445-hours-miles-q/#findComment-556755
Would you say these are better than an AMI 370 that has had the modifications done to it such as injectors, turbo, exhaust manifold etc ?
https://www.bigmacktrucks.com/topic/74445-hours-miles-q/#findComment-556758
An AMI that's been (deAMIed)  might pull better, but that MP7 is a pretty good little engine.  They had injector cup issues , common problem for them. Overall, they were a dependable driver friendly engine, and fairly good on fuel .  Still quite a few in service , for being offered one year and almost 20 years old now.
https://www.bigmacktrucks.com/topic/74445-hours-miles-q/#findComment-556768
