Brake pod mixing
  • 2 months later...
36 is common on mixer’s here du to the weight it’s ok to have one axle bigger but not one for on each! That said your safer with all  the same on all drivers are best! Steer axle brakes Must have matched pods even if you have roto chamber they must be both roto by our rules here! Common to have 24 on the front sometimes 20!As a side note long stroke pots are not inter mix able here either even though they are 30/30  0r 24/24 dumb but true!my belief is that every thing should have long stroke pots period!
Never knew they even made different stroke lengths for the 30/30 chambers..
Most long strokes have a square form around the ports for the air ( service and spring )  Geometry is all different for regular and long stroke. They make'm though.
16 minutes ago, Joey Mack said:
Macks, there are 2 1/2'' and 3'' maxi's..  the 3'' one's can be identified buy square cut ports for the air lines,,,  just in case you can read the lable or whatever...  Jojo
I know 24 cans are long or short but the 30 are just one length right..
11 hours ago, Mark T said:
No
Ok my bad,never heard anybody ask for a short stroke  30 at the parts store,our local Mack dealer has a huge cardboard box on the floor 6x6 filled with brake chambers all long stroke,I’ve just been grabbing them from there as long as. I can rember..
13 hours ago, Joey Mack said:
the rod length is not the issue here,  ther are many laengths of rods,,  the stroke of the plunger in the diaphragm is where the difference is.  the actual movement of the rod..   you can also see that the center section of the brake chamber is wider too..
the diaphragm is the most important component to the long/short stroke chamber,  2 1/2 vs 3 diaphragm side by side show considerable  difference in height. not good to put a 2 1/2 in a long stroke chamber. have seen the pressure blow apart the diaphragm from pushing it further then manufactured for.
The best identifier is the square port as mentioned  and No as mentioned! 30/30 is the most common these days on drum brakes ! Im not sure what they are using on the Disc  stuff as Im well removed from the business these days thankfully ! They look like 20/20 or 24/24 !
Discs are a whole other size. I'm learning about this lately.  Just changed some on my T880, they're like 24/18s or something.  Really need to pay attention anymore. Mix'n anything is a fast way to no brakes.
