My Mh had that same problem, does it go away under load? From what I've heard governor springs are usually the culprit. Finding people that work on Ambac pumps is tough but I think there are still a few out there. Finding parts is also pretty tough.
Best of Luck
https://www.bigmacktrucks.com/topic/74474-ambac-pump-rebuild/#findComment-557147
I used to pull the hand throttle up a bit incresing idle and it stopped bouncing with revs.
Would love to hear any results of experience tinkering with Ambac E6 pump though.
https://www.bigmacktrucks.com/topic/74474-ambac-pump-rebuild/#findComment-557157
Best of Luck
Yep it goes away under load or no load at all. Trying to cruise down the road at say half throttle is the problem. Have to treat the pedal as an on-off switch
https://www.bigmacktrucks.com/topic/74474-ambac-pump-rebuild/#findComment-557160
