Well,, Skydawg,,  I think you got your answer...   FJH,Brocky,and Terry..  are guys to pay atention too as well...  Too many brilliant guy's on here to name them all in a single post..   jojo
The hose place that I used supplied me with this stuff for anything to do with hydraulic fittings I would smear it on the threads and twist the fittings together I used it on stuff when I couldn't use tape or pipe dope.
To me, Teflon tape is a big NO-NO in any automotive application. Pipe dope or thread sealant applied with just enough to accomplish the task and not to excess, where you need to wipe it off when done. So not to repeat, I agree with Joey Mack's statement.
Anything with a tapered seat does not need sealant.  With that said, if the two fittings are dissimilar metals I would suggest never seize or light oil to keep them from galling up.
I learned a hard lesson just recently when I had to replace my AC compressor.  Seems after 8 yrs the metal line fittings and the aluminum compressor fittings were destroyed when I tried to unscrew them.  No easy way to clean the threads on the line fittings, so I had to replace the lines/fittings.  The compressor was junk anyway, so the fact it tore the threads on it was moot.  Lesson learned, the slightest dab of never seize will make it easier to work on in the future.
Stainless is another metal that needs lubricant if two simlar fittings are assembled.  Stainless against stainless will gall up very easy!
