Hello, we're looking at a potential donor truck to maintain parts for a workhorse Mack.  The donor is a 1975 Mack dump truck.  The main truck is a 1986 RL688LST Mack 10 spd trdl1070, E6 350 engine dump truck.  Are the tranny, running gear, engine, etc compatible for swap? Bolt patterns, mounts, etc?
https://www.bigmacktrucks.com/topic/74540-donor-truck/
The 1975 is going to have a 2valve ENDT675 or 676 engine. Virtually the same block, but there are some differences. Mostly I think there were bottom end reinforcing changes over time, and the head bolt quantity changed at some point. It'll bolt right in, but it'll be a weaker engine.  675 is a 237 HP engine, 676 is 283 HP.
https://www.bigmacktrucks.com/topic/74540-donor-truck/#findComment-558278
I would make sure your front mount is the the same your getting into the years where the front mount was changing to a two bolt mount from the trunnion arrangement on the newer unit! otherwise this would bolt in! also does the newer truck have a charge air cooler in front of the rad?
https://www.bigmacktrucks.com/topic/74540-donor-truck/#findComment-558285
I appreciate the responses, very good info. It seems like it may be best to look for a newer truck - donor or one less of an adventure to drive.  I cant get much more info from the guy selling the '75.   I was trying to get a door sticker picture atleast.  ultimately,  using running gear, or engine, from an older donor sounds like it will make the "newer" current truck weaker.
https://www.bigmacktrucks.com/topic/74540-donor-truck/#findComment-558324
