I know Australia has 240 volts.. I bought an adapter here in the States before we went Down Under to charge camera and phones ETC.. If England has a different power status you should be able to find an adapter.. Although you really do not need a block heater for starting until the temperature gets below 30 degrees Fahrenheit, 0 degrees Celsius..
Brocky
https://www.bigmacktrucks.com/topic/74545-plug-socket/#findComment-558354
Most all block heaters are made in both 120 and 240 volt variants, if the plug end still has a USA NEMA 5-15P in it then it would be safe to assume it is still 120 volt, if it has a NEMA 6-15 or British/Irish plug one would conclude it has been changed to the higher voltage.
 Testing the resistance will tell what voltage.
https://www.bigmacktrucks.com/topic/74545-plug-socket/#findComment-558355
