i have not tried this but if you cover any vents/holes ..... possibly yes. try  it!!
fueling is more easily diagnosed with a hand pump at pickup pump AND one down near tank.
i have added little hand primers to all my trucks at pickup pump(on injection pump) and  next adding another down near tank. any patching to get going on side of road may need system priming.  i have this setup on my CM currently and a leaky hand priming pump left me stranded once. very very old plastic hand primer pump was replaced and after trying to pull on a dryish??\open system through filters didnt work out. which i thought that was the purpose of a hand priming pump but hey ive learned. although could have been other leaks in the systems or even quality of replacement hand pump. whatever the case i say just install two hand pumps, call it a  day. Or maybe moving tank to same side as injection pump, closer may help idk.
Edited by glenbjackson
Can the lift pump in an ENDT 673 ever be in a "closed" position? I`m trying to prime the system w/ 10 lb of air into the fuel tank,vent blocked.I have the inlet fitting at the injection pump open,but after 10 min of compressed air,still no fuel at the IP.I filled both fuel filters when installing,but that was 2 wks ago.Maybe the scraper filter before the lift pump drained back into the tank.Is it safe to use more than 10 lb of air.I can`t see that it would matter,if I leave that inlet open at the IP.Thanks.
it sounds like the fuel pick up line is clogged, take the fitting off and see what comes out, a milk jug makes a good catch can..
