Huck's aren't any better than bolts, Rivets are stronger than bolts, but not Huck's,  Go ahead and replace with bolts.
 Both Huck's and bolt stretch under tension and "neck", a rivet expands when compressed (set) and fills the hole.
 Huck's a quicker in a mfg assembly line, and can't loosen, but aren't stronger.
