1947 ex-firetruck restoration
Go to solution Solved by steve s.,
James I have been down the road your on ,I have a 1954 Mack LS85 open cab , had a off frame started in 2009 took 2 years and lots of $$$$ plus . will never get money back out of it but didn't care. got many awards ,plaques, trophy's etc. , At musters I put up signs "Judges please Do Not Judge " .
  My current project is my fire company's 1934 Seagrave Suburbanite ,started as group project but just me now ,have a budget (small) trying to do most of work inhouse cleanup grease little rust etc. .will have to repower  ,hydra brakes, wiring ,fuel system , lighting, just to make presentable , slow process but that's my goal and will send out to repower .
  • 3 months later...
I haven't given up! I am still here, life has just been so crazy busy. I have finally been able to clean up the shop a bit so now I have a bigger area to work. My current thought process is that I want to get a "checklist" of what steps I need to do next so I can get the truck up and running. This is my current list
1-Clean up the shop
2-Take inventory of parts and roughly put the engine together (take lots of pictures)
3-Turn the engine over to see if it is ceased
4-Get the cab off of the frame and sit it on the ground (it is currently just sitting on a pallet which is on the frame)
What would you all suggest for me to either change on the list or add to it? I would like a pretty good list of things so I can try to knock out a few things at once.
I wouldn't worry about number 2, unless you know what your looking at it will be just making things more confusing
Start with, this part I think is a axle part, or a motor part or a brake part and so on
Just gather them together in piles or area's
Then just make a start, most things have witness marks, like were two parts that were painted as one came apart, just try assembling things like this, use different paint colours as a guide and so on
Most of the gear will be pretty easy to find the answers two
Paul
