The cooler on the bottom of my engine on driver side
if I open the pit cock on it shouldn’t I get water out of it
transmission cooler
there’s nothing coming out of it even when truck is running
I’m trying to drain coolant and change it out
Edited by Moparmike
https://www.bigmacktrucks.com/topic/74734-2000-mack-rd-688-e7-water-out-of-cooler/
  On 11/10/2024 at 10:19 PM, Joey Mack said:
I bet the pet cock pee holes are clogged with that coolant conditioning powder that comes in the filter kits..
Expand
Hey Joey Mack
you wanna replace the rear suspension bushings and u bolts for me
  On 11/11/2024 at 2:09 PM, JoeH said:
Coolant drain is a petcock on the lower radiator hose/tube. Approximate location is under the alternator. I assume this is the petcock you're attempting to get coolant out of?
Expand
Yes sir
there’s the radiator hose that runs to the cooler then there’s a set of transmission lines that goes to the cooler and a line that runs to the reservoir tank on the firewall all comes off the cooler that the petcock is in but can’t get anything to come out when I open it or even take it out
im thinking that it’s only cooling part of the system since it seems stopped up
  On 11/11/2024 at 7:53 PM, Joey Mack said:
have you pokes a small pick or something up in the hole?
Expand
Yes sir couldn’t get anything in it and didn’t want chance putting a hole in it
I think I’ll just remove the cooler and see what’s going on
I price it online 1200 smh lol
but I know it’ll make a difference in the temp I’m sure it runs around 180 all the time looking at gauge but it’s not cooling the entire motor
I worked it today put my hand on the radiator hose (bottom) and it’s hot put my hand on transmission lines just warm and the cooler is not hot
  On 11/12/2024 at 2:21 AM, JoeH said:
My '95 is only a 350, doesn't have that trans cooler thing.  Dumb question, is it actually plumbed with coolant or has it been bypassed?  Again, I'm sure that's a dumb question.
Expand
No it’s plumbed with coolant
it has a radiator coming from lower radiator that goes to it
then another radiator hose off the top that goes to the oil cooler As well
I believe it has 5/6 different hoses that comes off of it
Yeah that thing looks like a headache.
Most of our trucks over here run a cooler in front of, or below, the radiator.
Kinda the same as this. At least there can't be any contamination of fluids if it fails. Easy enough to swap out your one with a piece of pipe and run some hose extension to mount a cooler up front.
