  • 0
Engine swap
Question
1 answer to this question
  • 0
Local outfit here has had one for several years that is a 10 wheel dump has a C-15 and an 8LL in it and it’s crammed in up under the windshield but if a C-15 fits I would assume about anything common will fit. There are places that make wiring harness for putting about any engine in any common truck. Is the end cost worth it? Only you can decide that. At any rate good luck.
https://www.bigmacktrucks.com/topic/74749-engine-swap/#findComment-561906
Answer this question...
