12 hours ago, T-Mack1 said:
Full truck assembly at Macungie,  Two assembly lines.  One line for Conventional trucks,  one for cab overs.  We even assemble the frames again.  They out sourced the tire mounting.    Target is approx 120 trucks per day.  That is if the vendors can deliver the components we ordered.  Usually make around 100 to 110 a day.
Ok have to ask...what cabover models are being assembled now?....
Paul
My parents bought a 1955 B85 tractor in 1997. It had pulled a ladder for Harrisburg then Camp Hill PA. It was great fun to ride around in but a very rough ride. It has hydraulic brakes. They went out about 15 years and it has never been fixed. You have a great advantage if yours has air brakes.  I’m sure you can find a B85 with a canvas top to copy.  My father’s had a top at one time because it has snaps on the back of the cab. It would be a lot of work to make it a 4 door.  Might as well play with it the way it is.  Mike
Thanks Mike, cool there is another one nearby. I’ve seen your truck at my boss’s (John Haines) truck shows . Perhaps you should take your own advice and play with your parents truck as is, it’s only brakes my friend, and it is still a red convertible …..Jack
Edited by Jack Mack
saving attachment space
There is a place by Pottsville that handles all kinds of brakes for industrial applications. They have all kinds of odd stuff there, and do rebuilding of hydraulic parts, make control cables etc. They might be able to help get those hydraulic parts for that juice brake B85. They are in an old bakery building on if I remember right Bakery road. They got me some stuff for my juice brake Lancer Boss forklift that was made in Germany. I'll have to see if I can find the name of the place
Found It
https://www.airbrakeandpower.com/
Air Brake & Power Equipment Company, LLC
1048 Bakery Rd, Pottsville, PA 17901, USA
Edited by Joseph Cummings
Paul
The only cabovers Mack offers are the LR and Terrapro (TE). The LR is exclusively meant for refuse work, with dual steering wheels and a low enough cab that stepping into the truck is easy and safer. The TE is predominately used in trash trucks around here, but it's designed to be tougher to accommodate vocational use like concrete pumping. They also make the electric LR, but we all know how that's been going.
I haven't followed up on that much lately. I would imagine weight, and getting enough power into the facilities to charge them is a problem. It's not like you can just call up Billy Bob's electric and get him to install a 1,000KVA transformer to supply the chargers. That requires long term planning and in a lot of places 8 figure budgets
I helped put a quote together for ONE charger install, and it was mind boggling how expensive it was. Add on the fact that the EV truck has an incredibly short range, and it ends up making no sense to have one. I remember attending a class where one of the Paccar developers working on the EV program told everyone that none of the EV designs would have a great range, it's just not feasible yet.
On the subject of E trucks,I cannot see them working.the range of most E cars is small enough.So far I'v only seen one E truck.It was a Daf with a diesel powered refer body...the mind boggles!!!
Paul
Pepsi Sacramento required upgrades to the utility substation and powerline to be built to run their chargers, and they had to install a Tesla Megapack on the ground. Those Megapacks are 1 Million dollars installed a couple years ago. The project took 3 years.
Here is Pitt-Ohio's experience with electric trucks
1 hour ago, cruiseliner64 said:
Is the TE what was nick named the Bug Eye? There were a few Bug Eye Macks in the UK but none made it to Ireland as far as I know.I thought they looked nice.  ....
Paul
Never heard the nickname before, but here's a picture:
2025 MACK TE64 N41793 | Worldwide Equipment
