Try looking at a bus front axle, most of the buses in the last 20-30 years are air ride front and back
Town and city type buses have a kneel function, pull into pick up or drop people off and flick the switch and the bus lowers down nice and low to make it easier to let people on and off
Paul
Alright, crazy thought, but been thinking about putting a sleeper on the B….do you feel it would look out of place on a single rear truck?  We will most likely always have a dog that rides with us (wife and I), and the current one is darn tall, and could use the bunk as a bed.  Thoughts?
you would probably be limited to a small 24 inch sleeper unless you lengthen the frame.
Being I have the frame from the CH, I think I can add that to the original to extend it a bit.  That way I could keep the rear suspension on its original frame, and get a good section to extend it.
Up until I was thinking of the sleeper, I originally thought of going with a 156” wheelbase.  Now perhaps I would go closer to 180” to add a 36” sleeper?
Edited by wingrider
3 minutes ago, Freightrain said:
I stretched mine and added a 42" bunk.
I know you had pictures at one time of what you cut from the cab, but they no longer show up.  Do you by chance still have those pics?
I had them on Photobucket and when that site went rogue I deleted all my pictures.  I have some on Photoimage and now Google says it has issues and won't let me open it due to security issues.
This site has limitations on photos so I can't just dump a bunch on here.
Great idea about the sleeper but now you’re completely up in the air. Sounds to me like you almost have to use the CH frame to get it set up the way you want sleeper is probably not going to be cheap, but it will be happy with the results with all the Modifications. It looks like you got six one way half a dozen the other I probably mention that before, you pretty much, have a lot of work ahead of you but probably a fun challenge getting it all together. Good luck…. Bob
4 hours ago, wingrider said:
Lucky for me, I do know how to weld and fabricate.  My Dad was a pipefitter, so learned a lot at a young age.
excellent lets get started,,,,after you get done listening to the other half for a while,,,,,good luck with that:chili::notworthy:
  • Haha 1
you might also find it has taller legs,,,alotta  these oldies have no top end
You might wanna check out the Bob and Larry show. It’s on odds and ends video of his B model the day. I met him pretty cool good inspiration for somebody just starting out with a B enjoy
