Front seal leaking on front differential. Have movement when I push up or over on it   Can’t find model tag.  Found numbers and letters stamped into housing   Presume I need to replace bearings on input shaft.   Can I remove front sector and how do I set backlash or preload   I finally found new seal numbers
https://www.bigmacktrucks.com/topic/74839-%E2%80%9879-dm-differential-leaks/
