1 minute ago, Joey Mack said:
JC.. He has an E-Tech...  A different cam then an E-7.. Not sure if you knew that .. Jojo
E tech is the one with the inj pumps running off the cam right?
yes sir it is..  if you look at the picture he posted again you will see the wide cam lobe..  that is the lobe that operates the E.U.P. ( Electronic Unit Pump)...
5 minutes ago, 880joe said:
Are the offset cam keys available? Last time I checked they weren't available from Mack or PAI
They're available now, there's not a lot in the system, but they're available.
3 hours ago, Joseph Cummings said:
Mack E7 Camshaft Remanufactured Reman
  • (all #s) - $650.00 exchange and a core deposit of $300.00
https://atldiesel.com/pages/camshaft-service
Thank you for some direction. I did see that but I don't have part number so I have some things to figure somethings out. I also see that they can repair the camshaft that I have.
Just now, Joey Mack said:
the cam number is stamped on the front end of it. the front cover needs to come off..  Are you going to do the work, or someone else??
I've familiar with rebuilds but haven't done as many as you guys so any information is helpful
It's good that you are familiar.  ask any question you may have ,,,   SMALL--- or--- BIG..  we got this..  Many of us have been here, I myself have done dozens of these...
I wish I could post pictures again...  the H-Rings keep the lifters in-line..  the tool is about $400.00 at  tillman tools, there are other sellers. I promise I am not trying to make a mountain out of a molehill, I just want to help educate you..  with respect..  Jojo
I am passionate about these engines..
