I have some photos of Barletta B models in a junk yard in West Hazeto from around 2003.  I should Try to find them. They were orange and black.  A friend’s family has an off road park up there and had an orange and black N model water truck that must have come from Barletta. I don’t think I took a photo of that. Mike.
I remember Bartetta's and I used to go past Pittston Trucking their fleet was all B models that I remember when I was living in Harding their one mechanic got killed when he was adding air to a split rim tire I knew the guy but I can't remember his name. They hauled ashes out of the Harding powerplant.
22 minutes ago, harrybarbon said:
Looks like a B615, with alloy radiator and high mounted air cleaner, so it would be a 1962-64 model, being the years of the B615 with the V8 - 864
Frog was liv'n large drive'n that truck.
On 12/9/2024 at 8:40 PM, 70mackMB said:
Wow, never saw pinstriping that size before.    .....Hippy
In CT years back one construction co ==(Allen ) Beard  construction had all trucks  ;black/red which looked like circus wagons with the pinstriping and polish. also the was E Gasparri  waterbury ct had the chrome and polish. they bought a new DM -didn't like the paint on the rims , so they pulled the 10 tires and repainted the rims. it had a recall for chattering brakes ( cams factory installed backwards ). they stood over me as I pulled axles and let me know " don't get a spot of oil on the rims!
15 minutes ago, mowerman said:
Wow I didn’t know you could put them in backwards
issue was the S cam was in "backwards " in terms of the s operation going against drum/tire rotation. memory serves correctly it was only the front drive having issue. pull two tire sets /spread shoes(not remove) slide cam on driverside out switch with cam on passenger side.  rear drive the brake chambers mounted opposite  cam travel correct. simple factory screw up effecting ?// trucks nation wide ??
11 hours ago, mowerman said:
We had a barletta construction in my hometown wonder if it’s the same outfit Peabody mass  used to gas up thier pickups one of my first jobs Getty station
That is this Barletta family. We have a lot of them here in Hazleton
"Louis John Barletta is an American businessman and politician who served as the U.S. representative for Pennsylvania's 11th congressional district from 2011 to 2019. A member of the Republican Party, he served as mayor of Hazleton, Pennsylvania, from 2000 to 2010."
