Thank you Paul.  I have owned for 3 years. I do hope to spend a week or so putting the wiring back in it. The paint is ok. I could probably just wax it. I love the simplicity of the truck. When i did drive it around the block a few times, i was impressed with the torque it has. It will put you back in the seat for a second when i step on it.  Im think about adding a spin-on oil filter somewhere hidden from view so i dont take away from the original look of the engine, of course when i put an alternator on it, it will look modern.  I cant afford the alternator that looks like the original generator, at least not now..
The brakes on the K-7's will really stop the truck well even when loaded. I had 5 ton on mine (grossing over 18K) and no problem stopping.
The oil filter base contains the pressure relief for the system and must be retained. Installing a 2nd bypass filter, is easy enough but little is gained by doing so. To install a full flow the oil has to be re-routed from the pump to the filter base and back to the main oil rifle. Doing so places the oil filter ahead of the relief and that could cause problems if the filter plugged, or the lines got damaged. The pump is plumbed directly to the main oil rifle and the current filter and relief is T'd off of that.
Given the above, and the high sump capacity, low miles that my trucks see, I decided it wasn't worth the trouble and modifications to the block to install a full flow, and the bypass the truck came with is as good as any you can get spin-on.
Just my 2 cents worth.
Thank you GW..  I will give consideration to what you say.  The current system does work. I guess as long as sock filters are still around i can leave it like it is.  The oils pressure range was 15-35 psi as it sits.  I dont know what it is supposed to be. I dont have a good shop manual for the engine.  Not yet anyway..
Nice thing about spin on there’s lots of cross reference I recently bought a fuel filter for mine at AutoZone. It’s an add-on somebody replaced it through the years somewhere. I didn’t think of this until just now but I had a 48 Chevy pick up. I bought around 1986 and my truck was just about the same condition as yours except it really didn’t need anything except the paint job. I want up selling it shortly after. cause they had that 50 mile an hour rear end. and the only place in town with a hopped up pumpkin wanted too much for it. I decided to just get rid of it, but at the time I had a lot of irons in the fire.
That sounds about right to me well, why don’t you just buy a couple of them sock filters while they’re available and keep them for future reference
10 hours ago, harrybarbon said:
Hi Brocky, yes it is Ian's Chief. It is now owned by a guy in Brisbane who owns a major transport operation, another great guy and a gentleman. Ian was restoring the guy's B80 at the time of your visit. When the guy and his wife were at Ian's to see the B80 in progress, the wife saw Ian's chief, she asked if it was for sale and that afternoon they bought it. It is in an excellent home.
Is this their B model??? It was in the shop wile we were having Morning tea..
Brocky
Main bearings are hard to find, only NOS.  Your pressure sound good to me, I don't remember seeing a pressure listed in the manual.
Binderbooks used to sell reprints of the manual, but I don't think they are still around?
Thanks again GW.  I am fine with my current oil pressure.  I should have added this: that is the reading on the original gauge with the original style pressure sender.  I was happy that it worked.  I will certainly put a gauge on it next time i start it. I assume i can use any of the ports along the pan rail in line with the oil pressure sender..
yep, they are all cross drilling to the main bearing saddles.
I am surprised at how well the original gauges do esp oil pressure. I have a mechanical and electric both on mine and the electrical reacts quicker than the mechanical.
