I posted over a week ago and got no responses, so I'll try again. 2015 mack pinnacle with the mp7 engine. When the key is turned to the run position nothing happens, when turned to the start position the dash turns on like the key is in the run position. When you let off the key everything turns back off. Thought that maybe the key switch was bad so we replaced it but still have the same problem. Has anyone run into this problem and could someone possibly point me in a direction to start looking. Thanks.
https://www.bigmacktrucks.com/topic/74917-2015-mack-pinnacle-no-crank-no-start/
15 minutes ago, fjh said:
Sorry no one has posted ! as its not that common of a compliant ! Just stab in the dark ! I would try a new ignition switch!
We tried that already, problem still the same.
